February 10, 2025 at 1:49 pm
iwood
SubscriberHello,
I was hoping somebody with experience on sheet metal conversion (or flat plate development) would be able to guide me towards a fix on this issue.
I have a 3D model created in Ansys SpaceClaim with some bends, I've assigned the material and tried converting it to a flat plate. It successfully recognized all of the bends except for 2, which you can see in the picture below.
SpaceClaim returns an error that it is unable to create junctions at these locations, saying "sheet metal conversion error: wall faces are different thicknesses". This confuses me because I did a measurement on the thickness of plate at these locations, which is supposed to be 4.75 mm. As you can see from the measurement, that's exactly what it shows.
Any idea what could be going wrong?
Thanks in advance for your input.
Ian
February 11, 2025 at 7:36 am
Devendra Badgujar
Forum ModeratorHello Ian,Â
Let us continue our discussion through the Ansys Customer Space for this.Â
DevendraÂ
February 13, 2025 at 6:31 pm
Fabian Scr
SubscriberNot the Same Thickness?
February 18, 2025 at 12:51 pm
iwood
SubscriberThat's what one would think, but the thickness matches up with the rest of the part. I have a technical rep working on this with me. He couldn't figure out the cause of the issue so it was reported as a bug with the development team. I will post an update once I have it.
February 18, 2025 at 6:27 pm
Fabian Scr
SubscriberÂ
When its 0.001mm difference make spaceclaim Stop
You can Mark all Outsice surface Copy and Pace, Delete the solid and Mark all surface and pull it to the Right Thicknet, by me Help this in 99% of the Problems.
4949
1639
1386
1242
