Additive Wizard not able to generate support
    • ZengHuang
      I am currently doing the Additive Manufacturing Process Simulation. The above image is my impeller at the MAPDL. As I am using the Additive Wizard, it should generate support automatically as I selected create support. But nothing has happen after that step.
      Unlike what I did to the single blade simulation, I have successfully generate the support with the same step.
      Can I know why this happen and how to solve this? Thank you!
    • Kajal Khan
      Can you check it by changing the overhang angle in the wizard?
    • ZengHuang
      Yes, I have tested any value between 1 to 90 and it just doesn't work.
  • The topic ‘Additive Wizard not able to generate support’ is closed to new replies.
