February 7, 2025 at 12:15 pm
cngutis
SubscriberHi i was trying to do the mesh on Fluent (with Fluent meshing) but when finishing the mesh it crashes and closes the mesh window. When i try to enter again it appears blank like i show, then i manually need to add a component but the real problem is that it doesnt even let me import the geometry, like is not possible for me to click on file name to enter the geometry! Why could this be happening?
February 10, 2025 at 7:58 pm
Federico
Ansys EmployeeLooks like this mesh file could be corrupted. You might need to start over. Write the mesh file after each successful task, to ensure you can revert to this step if Fluent fails at a later step.
Ansys Innovation Space
- affinity not set
1414
1220
1118
1015
