January 29, 2020 at 12:43 pm
Talal
SubscriberHello,
My computer seems to not want to process stress or strain for a simple static analysis on MAPDL: "The requested S data is not available. The PLNSOL command is ignored.".Â
On other computers it seems to work just fine.
I have ansys studette 2019R2
January 30, 2020 at 4:54 am
ChristianGuzmanP
SubscriberHi,
Have you had any solution? I am having the same problem
I am doing a simple ex.
This is the code:
FINISHÂ Â Â Â Â Â Â Â Â Â !close all previous modules
/CLEARÂ Â Â Â Â Â Â Â Â Â !clear all previous models
/TITLE, Cantilever beam
/PREP7Â Â Â Â Â Â Â Â Â Â !start PRE-PROCESSOR MODULE
ET,1,SOLID185Â Â Â !element type #1: SOLID185 (3 DoF)
KEYOPT,1,2,3Â Â Â Â !element #1: keyoption 2=3
MP,EX,1,210000Â Â !Young's modulus for material #1
MP,NUXY,1,0.3Â Â Â !Poisson modulus for material #1
BLOCK,0,2000,0,100,0,200Â Â !create a solid of 2mx100mmx200mm
LESIZE,5,,,40Â Â Â !40 divisions in line 5 (2m)
LESIZE,6,,,4Â Â Â Â !4 division in line 6 (100mm)
LESIZE,10,,,8Â Â Â !8 divisions in line 10 (200mm)
MSHAPE,0,3DÂ Â Â Â Â !hexaedral-shape: Element shape to be used for meshing
VMESH,1Â Â Â Â Â Â Â Â Â !mesh volume
FINISHÂ Â Â Â Â Â Â Â Â Â !end of PRE-PROCESSOR MODULE
/SOLUÂ Â Â Â Â Â Â Â Â Â Â !start SOLUTION MODULE
ANTYPE,0Â Â Â Â Â Â Â Â !static analysis
NSUBST,10,0,0Â Â Â !perform the analysis in 10 sub-steps
OUTRES,ALL,1Â Â Â Â !write results for each sub-step
TIME,1Â Â Â Â Â Â Â Â Â Â !end time of the analysis
DL,10,,UY,-1Â Â Â Â !applied 1mm displacement in vertical direction at x=2000mm.
                !bottom line of the area
DA,5,ALLÂ Â Â Â Â Â Â Â !clamped area at x=0
SOLVEÂ Â Â Â Â Â Â Â Â Â Â !solve the current load case
FINISHÂ Â Â Â Â Â Â Â Â Â !end of the SOLUTION MODULE
/POST1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !start Post-Processor module
PLDISP,1Â Â Â Â Â Â Â Â Â Â Â Â Â !plot the deformed shape
PLESOL,S,EQV,0,1.    !contour plot of Von Mises stress
PLESOL,S,X,0,1Â Â Â Â Â Â !contour plot of stress in X-direction
PLESOL,EPEL,X,0,1.   !contour plot of strain in X-direction
PLESOL,EPEL,1,0,1.   !contour plot of principal strain
So, APDL doesn't show the stress and strain
Any of you have any idea how to solve this problem?
Thanks
January 30, 2020 at 6:12 pm
Talal
SubscriberHello,
Yes i have found a solution.Â
-Type in search bar on your pc and open : Mechanical APDL Product Launcher
-Select the tab : High Performance Computer Setup
-Change from "Distributed Computing (DMP)" to "Shared-Memory Parrarel (SMP)"
i haven't tweaked with the other settings you can try. Try without touching the rest first.
- The topic ‘ANSYS MAPDL doesn’t calculate stress’ is closed to new replies.
6710
1313
