January 12, 2025 at 3:26 am
naveen.gunasekaran
SubscriberHello,
I have been trying to simulate crushing of a 3D core auxetic structure with composite plies with static structural nonlinear analysis for calculating the specific energy absorption since composite debonding simulation is not possible in explicit simulation in ansys. I am ending up with error for high distortion of the elment on the composite plies, Here is the heads up, when I try to simulate just the two composite plies debonding with the axial displacement (i.e. Remote displacement) of 10 mm, the results are perfect. When I add a crushing indenter as a contact, then the distortion problem occurs. I have tried the following things:
- Refined the mesh quality finer until 0.5 mm, whereas the mesh size was 3 mm for the remote displacement; despite that, it works fine.
- I had the step size, initial 1000, min 150, and maximum 3000. Just to ensure loading is small enough to converge.
- I enabled large displacement; try the stabilization damping factor to 0.1 value.
Its evident that remote displacement-based crushing and plate-based remote displacement have different behaviors. The plate-based remote displacement has convergence issue;3D kindly suggest me what has to be done. If I complete the plate-based remote displacement, then I can somehow finish the debonding with a 3D core.
Regards
Naveen
January 12, 2025 at 4:15 am
4597
1500
1386
1209
