Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Visualise pathlines across periodic instances › Reply To: Visualise pathlines across periodic instances
January 10, 2025 at 11:23 am
Oh, I found a solution on our customer support space. Was actually not aware of this facility. In any case it there does not seem to be a direct solution but seems to be a workaround, rotating mesh, appending case and data, fusing and repeating for all instances. A little bit of a mission unless there is a better solution in later release?
