Ansys Learning Forum Forums Discuss Simulation Fluids Help generating flow path axial turbine blade with export points Reply To: Help generating flow path axial turbine blade with export points
V.P
Check if the blade height is higher than the shroud-hub height. Ensure the blade height is taller than the shroud sketch line when viewed perpendicular to the xz plane. Blade surfaces should intersect the hub and shroud lines.
