Ansys Learning Forum Forums Discuss Simulation Fluids Rocky coupling warning Reply To: Rocky coupling warning
jackson.dasilva
Hi Saeed.
The warning indicates a potential compatibility issue between the compiled User-Defined Functions (UDFs) and the current build of Fluent. Update Rocky and Fluent to the same version.
If you are using UDFs compiled with an older version of Fluent, recompile them using the correct Fluent build to avoid issues.
Best regards.
