Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Script Error Ansys › Reply To: Script Error Ansys
January 6, 2025 at 3:45 pm
I have changed the operating system language to English (United Kingdom). I have checked and modified the temporary files directory (using the command prompt with %APPDATA%) as well as the project folder directory. Both now contain only ASCII characters, but the issue persists.The temporary directory (TEMP/TMP) has also been changed to C:\Temp to remove special characters from the file paths. However, despite following the steps you described, the issue has not been resolved.Â
