3D Design
3D Design
Creating lines inside imported geometry
    • Qbzomatique
      I have an imported geometry that i would like to import to do a simulation inside steady-state thermal module. I am not sure whether it is possible to be done. If it is then could you please tell me if there is a way to insert lines inside this pipe body?
      Please find the screenshot of the model below.
      Thanks a lot!
      ANSYS Staff are not permitted to download attachments. Use the Insert Image button to put them in the post.
      It looks like you have the geometry in SpaceClaim. Please attach the .scdoc file in your reply so I can try some things.
    • Qbzomatique
      https://mega.nz/#!nhV0xKrR!xTEmMe4N9YxrY_TmqBVeqKi2OSukWPIFTEo3cqXhsvo
      Thank you very much for help. If you have any other hosting service preference please let me know and I will reupload.
      You can easily sketch lines and arcs at the center of the circular pipes. The other pipe is not circular, so would take a bit more work.
    • Qbzomatique
      Thanks a lot. The other pipe is circular as well though. Now I am just wondering when I set these lines to have a flow in steady-state thermal if they won't overlap where they merge and if the different diameters will somehow create any difference.
      I would use Fluent to solve the thermal model and not try to do it in Mechanical. I don't know what happens when lines branch in Mechanical.
    • Qbzomatique
      I have already used Fluent and CFX to do this case, but I do it for my master thesis which is about benchmark of the CFD software possibilities and I was thinking of comparing CFX, Fluent, steady-state thermal from Ansys and Autodesk CFD. But I guess I will just leave the steady state thermal out. Thanks for help!
Viewing 7 reply threads
  • The topic ‘Creating lines inside imported geometry’ is closed to new replies.
