January 18, 2020 at 9:34 am
amirmohammad
SubscriberDear friends,
I'm working on the validation of an FIV case, which for making phase difference between force and displacement, I used an initial velocity in the structural, but after several coupling step, the drag force becomes constant, therefore the structure doesn't fluctuate, the drag force is more than the amount mentioned in the original case which shows vibration in the structure.
any suggestion will be appreciated
January 20, 2020 at 3:46 pm
Forum ModeratorWhat does the flow field & CFD mesh look like?
January 20, 2020 at 6:54 pm
amirmohammad
Subscriber -
January 21, 2020 at 11:14 am
Forum ModeratorAnd the flow field?
January 21, 2020 at 4:49 pm
January 22, 2020 at 3:55 pm
Forum ModeratorFocus around the centre obstruction: what does the velocity field look like on a plane?
January 23, 2020 at 7:34 am
January 23, 2020 at 4:11 pm
Forum ModeratorOK, so the geometry is as expected. Now look at a plane of constant z through the inlet/outlet centreline. Focus on eddy shedding.Â
As an aside, what licence are you using? Ie home or Uni?Â
January 23, 2020 at 5:01 pm
January 24, 2020 at 11:44 am
Forum ModeratorNot sure it's the turbulence model to blame: read up on eddy shedding as I suggested. I think you've found an equilibrium condition.Â
January 25, 2020 at 4:51 pm
January 27, 2020 at 4:42 pm
Forum ModeratorIt's a displacement with a time, that should give velocity?
February 1, 2020 at 4:44 am
amirmohammad
SubscriberI understand what you're saying, but the point is, the velocity in two mediums is not the same in one step.
in several articles I reviewed, all used CFX for solving the CFD part, is there any reason for that ???
February 4, 2020 at 2:32 pm
Forum ModeratorNo reason to use CFX over Fluent, the preference may be down to the user .Â
Velocity in the tube may not have much effect on the tube shape if the outer flow dominates: why you aren't seeing eddy shedding is a bigger question.Â
February 23, 2020 at 11:14 am
amirmohammad
Subscriberare you saying the mesh is the problem???
the issue I just come up with is at the first I run my structural separately and I see major displacement, acceleration, ... but in system coupling, I run the same condition and the fluid doesn't strike the tube yet but the solution is not the same.
- The topic ‘The force becomes constant in two way FSI’ is closed to new replies.
- affinity not set
4362
1494
1375
1198
.jpg?width=690&upscale=false)
