January 13, 2020 at 11:36 amandimens13 SubscriberPlease can anyone give me an insight into the methodology of changing loads steps in load cases and finally retrieving the results for the load cases?
 example; Suppose I apply inertia loads on a body thus; 1g vertical, 1g lateral and 1g longitudinal as my load steps, how to do I convert this to a load case such as; 1g vertical + 10% of 1g longitudinal +30% of 1g lateral. Many thanks in advance.
Viewing 0 reply threads
- The topic ‘load steps to load cases in ansys workbench’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
                        1487
                        1363
                        1194
     You are navigating away from the AIS Discovery experience
