    • elsaeed
      I want to simulate an energy source term describe the solidification and melting process of phase change material encapsulated in spherical capsules and packed in a thermocline tank.
    • elsaeed
      the term source is   s= - d((1-phi)*rho* DELTA H))/dt,
    • elsaeed
      What's the question? Source terms are covered in the UDF manual.
    • elsaeed
      WHEN I ENTER THE SOURCE TERM OF THE LATENT HEAT THE TEMPERATURE DISTRIBUTION NO CHANGED, IT MUST BE INCREASED TO A CERTAIN VALUE AND THEN REMAINS CONSTANT DURING PHASE CHANGE PROCESS AND FINALLY INCREASED. BUT WHEN ENTER THIS UDF SOURCE THERE IS NO DIFFERENCE IN TEMPERATURE DISTRIBUTION. WHY?
    • elsaeed
      SOURCE TERM OF LATENT HEAT WHICH DESCRIBE THE MELTING AND SOLIDIFICATION PROCESS OF ENCAPSULATED PHASE CHANGE MATERIAL INSIDE THERMOCLINE TANK.
    • elsaeed
      phi IS the porosity of the packed bed,
      rho is the solid density of pcm,
      DELTA H is the latent heat content which is a function of temperature which is varies with time
      dt is the physical time step
      so, HOW can I write this udf source correctly?
    • Amine Ben Hadj Ali
      Edit moving to fluid.
      Did you check customization Manual as well as the melting solidification model?
Viewing 8 reply threads
  • The topic ‘UDF’ is closed to new replies.
