January 12, 2020 at 1:57 am
Jabaly
SubscriberDear All
I'm trying to apply a constant magnetic field on a closed-loop cycle, and I have good results without magnetic field. Applying magnetic field must affect on the mass flow rate, therefore the velocity must decrease.
The problem is:
There is no effect on the velocity when I apply the magnetic field at the right and left walls of the loop (x-direction).
I think I have a problem with applying magnetic field in fluent, is there any tutorial that helps me to understand the concept of MHD? , or may you help me here, if you worked on that before?
Note: I've used the manual when I applied MHD, so I need your experience with MHD.
Thanks a lot
January 13, 2020 at 11:13 am
Forum ModeratorCan you check the fluid is picking up the field: ie what causes the fluid to see the field? It's not a model that Amine & I have used so we may be of limited help on this one.
January 13, 2020 at 6:22 pm
Jabaly
SubscriberThank you for replying! appreciate it.
yes, you're right. The contours of the field have been appeared but that didn't affect the fluid. I don't know why the fluid did not pick the magnetic field so far, so I need your help about how can I say to fluent: "The magnetic field must affect the fluid flow".
plz see an attached pic if I have to change anything with,
- The topic ‘Magneto-hydrodynamic (MHD)’ is closed to new replies.
3597
1283
1117
1068
983
