January 10, 2020 at 6:15 pm
HZ776
Subscriber Hello,
I was doing a non-linear buckling analysis with workbench. I inserted a mesh refinement in the initial "Static Structural" system and clicked update. It reported an error as "Update failed for the Model component in Static Structural. Update of the Model component in Static Structural did not mark container as updated(final state is Modified)".Â
What should I do to solve this problem?
Thanks.
January 19, 2020 at 9:51 am
peteroznewman
SubscriberDon't use mesh refinement to perform a non-linear Static Structural analysis. Use Mesh Controls to manually refine the mesh and keep track or results.
- The topic ‘Mesh Refinement Updating Problem’ is closed to new replies.
Ansys Innovation Space
1193
1086
1068
952
