January 10, 2020 at 1:16 pm
Pluto922
SubscriberAfter calculating fluent DPM, how can I show the mass conc of the solid particles on some cross plane?
January 10, 2020 at 3:50 pm
Forum ModeratorI find contours to be quite effective.
January 13, 2020 at 2:50 am
Pluto922
SubscriberThank you. But I used the contours of pressure, density, velocity, turbulence, discrete phase variables, discrete phase sources, properties, wall fluxes, cell info, mesh, residuals, derivatives and anyone could show my wanted. Wasn't my DPM model coupled? However, I could see my solid particles tracks in particle tracks.
January 13, 2020 at 10:04 am
Forum ModeratorCouple the particles and run the model until you have an update on the tracks. Concentration should now be available. Remember the DPM is Langrangian on the Euler fluid solution.
June 10, 2020 at 5:10 am
June 10, 2020 at 11:12 am
Forum ModeratorCan you replot with node values off?
June 11, 2020 at 3:30 am
Pluto922
SubscriberSorry, I can't. I used Post in CFD-Post and I don't find the option about node values. Do I need Post in Fluent?
June 12, 2020 at 10:20 am
Forum ModeratorAh, do the post processing in Fluent. CFD Post doesn't work as well especially with particle tracks.
June 17, 2020 at 3:22 am
June 17, 2020 at 10:38 am
Forum ModeratorCan you post a screen shot of the DPM panel?
June 18, 2020 at 2:33 am
June 18, 2020 at 10:54 am
Forum ModeratorThat's more or less the same set up as I'm using on a client case. Can you replot with local range and turn off node values. You may also want to increase the number of streams as 2 per cone is a little coarse and I'd set the start/stop angle to 0 and 359 degrees.
June 19, 2020 at 3:24 am
June 19, 2020 at 3:52 pm
Forum ModeratorGo to the contours panel and plot the contour you had earlier, but with local range and with node values deselected. The scatter on the xy plot means you have a DPM Concentration, so the model set-up is mostly there.
June 23, 2020 at 3:56 am
Pluto922
SubscriberThank you. And I don't find local range in my contours panel, so I try to select auto range.
Maybe I made it ! I used R-R distribution in DPM model and then I could get a picture of DPM conc on outlet plane.
However, selected node values and not, the DPM conc max is different. Why? What is the true number?
June 23, 2020 at 2:06 pm
Forum ModeratorNot global is local: may not translate well or be as obvious as I thought!
The difference is graphics smoothing. Node values ticked will give smooth contours, off is the exact facet/cell value. As the mesh is refined the values will match.
June 24, 2020 at 3:12 am
Pluto922
SubscriberI got it! Thanks a million!
- The topic ‘Post in DPM and how show the praticle mass conc on some cross plane?’ is closed to new replies.
4934
1638
1386
1242
