Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How can I do plate heat exchanger analysis? Please help › Reply To: How can I do plate heat exchanger analysis? Please help
December 20, 2024 at 2:17 pm
That middle image - the wall setting is not the default. That should be coupled and then set the material & thickness in one or other of the pair. Otherwise Fluent has no way to pass heat between the two sides, and that's likely why your hot channel isn't cooling & the cool channel isn't warming.Â
