Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Converting .DMIG to .SUB Superelement / Condensed Part › Reply To: Converting .DMIG to .SUB Superelement / Condensed Part
Thank you Chandra for the quick response! I am not much of an APDL user so I am slowly working through this. I can’t seem to get past the following error:
 *EXPORT Command : Nodes need to be defined in Ansys prior to export a  Â
 new SUB file.  Â
I have defined the superelement's boundary nodes with XYZ coordinates (e.g.: n,1,0.0,0.0,0.0) that are defined in the DMIG and should carry over into the SUB as "master nodes" or "interface nodes" and I have exported those nodes to the .sub as well, so I’m having trouble understanding what more definition is required.
