Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Location of results when using python or cmd to call ls-run to calculate k files › Reply To: Location of results when using python or cmd to call ls-run to calculate k files
December 17, 2024 at 9:19 pm
Many thanks for your assistance. I have a further question. Is it possible to set the maximum running time for the simulation through the subprocess.run command? If the running time exceeds the maximum time, this job will be neglected and then switched to run the next .k file.
