Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Initial Velocity Generation › Reply To: Initial Velocity Generation
December 16, 2024 at 8:06 pm
Hi Valerym,
I created a simple cube tensile model and applied the same keyword card to define an initial velocity. As can be seen below, the displacements are positive as expected given the positive y-velocity provided. STYP in my model is 2 (i.e part ID) but is 1 in your model (i.e. part set ID). Make sure that your "part set #1" only includes the part you want to apply the initial velocity, not any other parts.Â
Thanks,
Pedram
