Ansys Learning Forum Forums Discuss Simulation General Mechanical CINT,TYPE,SIFS,Par2 command and auxillary field; I am confused! Reply To: CINT,TYPE,SIFS,Par2 command and auxillary field; I am confused!
Daniel Shaw
The behavior of the auxiliary stress fields is explained in the documentation for the CINT ommand.  I believe that the other section of the documenation first explains the default and then explains the user options.
I
