Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › nCode Issue with corrupt results › Reply To: nCode Issue with corrupt results
December 13, 2024 at 3:50 pm
danielshaw
You can verify that the results files were read in the Simulation_Input glyph. You can plot the stresses read from each results file to verify that the proper results files were read. To access DesignLife results from within Mechanical, you need to RMB > Update the Solution and Results cells of the DesignLife system on Workbench. As I showed earlier the External DesignLife Fatigue Results is just another Solution output item in Mechanical.
