Ansys Learning Forum Forums Discuss Simulation LS Dyna Location of results when using python or cmd to call ls-run to calculate k files Reply To: Location of results when using python or cmd to call ls-run to calculate k files
rji229
Thanks for your advice. If I manually use LS-Run, the result d3plot files are in the current .k file directory, there is no problem.
I use Ls-run because I found an online tutorial that said putting the command in "cmd" could run .k files. I don't know how to use LS-DYNA command lines directly in the Python script. Are there any references, instructions, or examples that I can learn from?
