Ansys Learning Forum Forums Discuss Simulation Fluids Fluent-Rocky coupling simualtion: iteration stops but no error shows. Reply To: Fluent-Rocky coupling simualtion: iteration stops but no error shows.
Lucas Bertollo Baggio
Hello z.sang,
I would suggest you to check if there is any warning in the simulation .log files (from the simulation folder). If there is nothing to help with the error cause, you may open a ticket for the Rocky support and send your case and files to be analyzed.
Best regards,
Lucas
