Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Radiation to Surroundings › Reply To: Radiation to Surroundings
December 10, 2024 at 3:59 pm
It could be a bug, but you made a very big mesh when you set the element size to 1mm. You may have hit an untrapped limit of your computer. Are you running on a lap top with limited memory? Do you have access to normal tech. support?
