December 10, 2024 at 5:51 am
December 11, 2024 at 12:49 am
Kyle
Ansys EmployeeHi, I don't think there is a built-in element in the Element Library that will do this. You will have to create a custom element with S-parameters. The best way to do this is probably with a Scripted Element that uses the setsparameter command. The "Frequency Dependent Transmission" element in the "scripted_elements.icp" file on the Scripted Element page uses this approach. You can use this to set the amplitude of the S-parameters to match the amplitudes of your filter.Â
1305
