December 9, 2024 at 6:59 am
hdyang
SubscriberHello,
I am researching frequency up-conversion.
Is it possible to use a short source wavelength in FDTD and check the frequency-domain field and power monitors at other broad band wavelengths?
December 9, 2024 at 7:36 am
hdyang
Subscriberexample)
short source wavelength : 2um
broad band wavelengths : 0.4um ~ 1.5um -
December 9, 2024 at 7:05 pm
Kirill
Forum ModeratorDear Subscriber,
By default, the DFT Monitor uses the source spectral limits. However, you can modify this as follows:
- Navigate to Monitor Settings.
- Under the General tab, check override global monitor settings.
- Uncheck use source limits and set your desired range of interest.
Please note, that due to the nature of FDTD algorithm the finite duration/bandwidth of the source is always used. See Can we use a dipole source with a single frequency?Additionally, refer to the article Frequency-domain Profile and Power Monitor – Simulation Object – Ansys Optics for more information.
Best regards,
Kirill
Ansys Innovation Space
1057
1051
896
882
