Ansys Learning Forum Forums Discuss Simulation Fluids Thermal analysis problem Reply To: Thermal analysis problem
OK. So the outer wall is fixed at 20C, but you're adding in some W/m3 to the centre solid? If you fix a flux AND the temperature what might happen? Hint: read up on what the convective wall option does.
