solid to solid contact boundary conditions
    • mo9225
      Hi guys,
      I´m working on a heat transfer Problem where a copperplate, which is in a tank, is heated up. The thermal energy of the copperplate shall be conducted via a conductor to the tank
      my question is, how do I describe the process of heat transfer in the boundary conditions for contacts between solid and solid, and do I have to specify boundary conditions for interfaces in the wall zone as well?
      One last thing: will it be a problem to inclued a heat source in a sealed tank?
      Hope you guys can help!
      Thanks and all best,
      Mo
    • DrAmine
      First of all do you conformal mesh? According to the images you shared you have interfaces. As such create the interface with option coupled wall between the solids (side a and side b of the interface)
    • mo9225
      Hey Amine,
      Yes I created a coupled wall within the mesh interface option. Afterwards source and target contacts will apear in boundary conditions in the wall section. At this point I don´t know how to define them properly. Also the interfaces between solid and fluid appear in the boundary condition area too.
    • DrAmine
      Please list the interface in the interface panel and past the output from the console there.
  • The topic ‘solid to solid contact boundary conditions’ is closed to new replies.
