Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Updating a Lumerical example › Reply To: Updating a Lumerical example
December 3, 2024 at 6:08 pm
kghaffari
Hi Sara,Â
Thank you for posting your question. Can you please share the inputs and results for each scenario? Specifically, please share the gap length you are simulating for each case (a simple schematic can be helpful too) and the loss/Vpi results for each case. I will then run the example with the same setting to reproduce and troubleshoot the issue you are having. Thank you.
Khash
