Welding Simulation
    • saransh.verma2810
      I want to simulate TIG welding in ansys using moving heat source and element birth and death method and using convection and radiation as thermal boundary conditions.
      I am getting error each time
      Please Help Me.
      Error and pictures
      *** ERROR ***                           CP =       7.922   TIME= 17:32:12
       The value of TEMP at node 2486 is 9199447.37.  It is greater than the
       current limit of 1000000 (which can be reset on the NCNV command).
       This generally indicates that there are no temperature constraints or
       convections applied.
    • Ashish Khemka
      The error indicated here indicates that heat us not getting dissipated from the body containing node 2486. Can you please share the images showing how you have applied the boundary conditions? Do you have a convection boundary condition defined in the model?
      Ashish Khemka
