Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Workbench LS-Dyna – Bodie penetrations during droptest › Reply To: Workbench LS-Dyna – Bodie penetrations during droptest
December 2, 2024 at 1:06 pm
Hi Nanda, thank you for your input. I use the following way of working (in line with the droptest tutorial I followed).
For interactions between the parts that collide with each other, I use the body interactions scoped to all bodies. When parts are bonded, I add a bonded contact to them. to prevent parts from going trough the floor, I also added a seperate contact propertie between them and the floor.
Is this correct way of working, or should I not use body interactions at all?
