Ansys Learning Forum Forums Discuss Simulation Fluids Total pressure data of the simulation is not correct. Reply To: Total pressure data of the simulation is not correct.
Essence
Assuming the y+ ~ 1, growth rate of the entire domain is less than 1.2 and good orthogonal quality, please note the operating pressure you have applied. Therefore, the pressures you see will be relative to the operating pressure. You can also apply absolute total pressure if you need. You can also use High Order Term Relaxation, High Speed Numerics and CASM in Methods for stability. If you have moving shock waves, use Explicit instead of Implicit.Â
