Ansys Learning Forum Forums Discuss Simulation Materials Temperature-dependent viscosity model used in FLUENT flow analysis Reply To: Temperature-dependent viscosity model used in FLUENT flow analysis
Fluent will use the Fluent model, and Poly data (Polyflow) will use it's own documented equivalent.
