December 11, 2019 at 2:33 am
anikethase
SubscriberHi,
I am facing a problem with the tool (Cylindrical Roller) movement on the surface of the blade profile. I want to roll as well as translate the roller over the predefined path on the blade. The part modeling is carried out in Solidworks. The blade profile designed using the Flex tool in Solidworks. The geometry of the blade is in the 3D plane with bending in various planes. (not 2D, like a Sheet in a plane)
Can anyone help me to give the motion to the roller on the blade profile? How to give a path to the roller (whether it should be intermittent by using coordinates or continuous by defining a line of path)
December 11, 2019 at 4:49 am
- The topic ‘Static Structural Analysis of Propeller Blade’ is closed to new replies.
1312
