November 24, 2024 at 1:19 pm
muhammadagussriharto
SubscriberHi, guys. I just wanna ask something relate to my model and the result is appropriate accurately even though there's need experiment to get "actual result"Â
So, Let's start .Â
I cofidently at beginning when I solve the holllow beam I made and the settings have been made . but there's something a little make me not put confident on that . You may like ask , where and when?
Look image on the below:Â
minimum occurs on: Midsurfaces 1Â
maximum occurs on: Midsurfaces 2Â
If the "occurs" happen different side , so I predict the result of deformation not correct or inaccurately.
I assume THAT WIL BE CORRECT if the minimum occurs and maximum occurs happen on one side "only'Â
So , is there any advice or opinion for that . I really need help .Â
at below the geometry look like . btw , I'm using midsurface because thin structure .Â
November 25, 2024 at 10:12 am
erik.kostson
Ansys EmployeeÂ
See this post that explains some important aspects/points of modal analysis.
https://innovationspace.ansys.com/forum/forums/topic/unreasonable-behavior-of-a-structure-during-a-modal-simulation-2/
I would also suggest to take our free modal analysis course (search under courses):
https://innovationspace.ansys.com/product/modal-analysis/
All the best
Erik
