December 9, 2019 at 1:58 pm
edoardo
SubscriberHello everyone,
My latest assignment consists in simulating the loading condition for a flexible pivot:
while I successfully simulated the loading in tension, I'm struggling with the compression case, which is something like this:
so i fixed the yellow sleeve, and applied a remote force on the green sleeve (both sleeves are rigid bodies)
here i hide the green sleeve, to show the fixed support on the end of the flexible elements (which are bonded to the sleeves). I then applied a remote force on the yellow sleeve.
When I try to solve, I get something like this:
This is what I get after already trying to solve the bisection issue by increasing the initial substeps with a factor of 5 from 100 to 500, and after increasing the mesh refinement where the Newton-Raphson residual told me to. Now I'm out of ideas.
Here is the model if anyone wants to take a look at it:
https://drive.google.com/file/d/1NsHx6BeRY8W1aO4cWu81bKvwD_S8hhSu/view
Thanks in advance for the suggestions
Edoardo
December 16, 2019 at 10:43 am
Aniket Chavan
Forum ModeratorAnsys employees are not allowed to download anything from the student portal. What error do you get in the solver output file?
-Aniket
December 17, 2019 at 7:52 am
edoardo
Subscriberhello Aniket,
I found a way to solve my issues.
- The topic ‘Simulating a compliant mechanism’ is closed to new replies.
6485
