Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CHT-Simulation (Steady-state) › Reply To: CHT-Simulation (Steady-state)
November 20, 2024 at 1:07 pm
I think you've got a few threads on this topic, this will be the last one.Â
Without knowing the device layout it's hard to comment, but I'd also be very wary of setting a nonconformal on the solid-fluid surface when you're looking at VOF and heat transfer. Re the cooler sections, you're correct they shouldn't drop below the minimum temperature, please check there aren't any nonzero heat flux boundaries too.Â
