Ansys Learning Forum Forums Discuss Simulation General Mechanical Rigid body motion in coupled field transient Reply To: Rigid body motion in coupled field transient
engr.rohan7
Yes the initial contact status is closed. Initially the interface treatment was add offset, but now it is set to adjust to touch. Load is also ramped. The time increment as you suggested is further reduced to increment the load slowly. I will get back if any issue occurs.
Rohan.
