RGP-Table generation for Fluent using System Coupling
    • conni
      The 2019R3 Version of Fluent allows for the use of rgp-tables like in Refprop (beta feature).
      To generate such tables it is recommended in the Beta Features Manual to use the System Coupling command console (which is launched under Windows by running the systemcoupling.bat batch file).
      When executing the Code  as listed in the Manual (but for butane instead of h2o), it seems to work, , then outputting:
      "Writing RGP File...
      Filename is BUTANE-med.rgp
      Writing Header Information...
      Writing BUTANEL 2D tables...
      Writing BUTANEL Saturation tables...
      Writing BUTANEV 2D tables...
      Writing BUTANEV Saturation tables...
      This is the last Output, it seems like the Programme then stops. However, I cannot find the file 'BUTANE-med.rgp' anywhere on the Computer... Does anyone know where the rgp file would be saved by Default, or if there could be a Problem with proceeding in that way so that there is another reason that i do not obtain a rgp-file?
      Thanks in Advance!
    • DrAmine
      In the working directory if not else mentioned in the docu. Issue a search in file explorer.
    • conni
      Thank you for the answer. I tried a file Explorer search, but it did not find any file… Could it be that there is a Problem that no file is created? Should, if the process is successful, another message turn up in the command prompt after "Writing BUTANEV Saturation tables… " ?
    • harrivin
      Dear conni,
      Did you manage to locate where the RGP file is located?
    • DrAmine
      It would write the files in the directory where you execute the command (tested today).
    • Tombock
      I have the same error, I don't find the rgp files after the end of the scriptn
    • DrAmine
      It would write the files in the directory where you execute the command (tested today). nn
    • Tombock
      Thanks DrAmine for the fast answer!nI have already check all the folders and the current directory, but I don't find the .rgp files. It's like the script doesn't save them.nDo you use this script 6.1. Real Gas Property (RGP) Table Files (ansys.com) ?n
Viewing 7 reply threads
  • The topic ‘RGP-Table generation for Fluent using System Coupling’ is closed to new replies.
