Ansys Learning Forum Forums Discuss Simulation General Mechanical Harmonic Analysis not being performed on PZT patch Reply To: Harmonic Analysis not being performed on PZT patch
ErKo
Hi
I would suggest to use WB mechanical and not MAPDL.
SO use the coupled field harmonic system in WB.
In help there is a tutorial:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v242/en/wb_wbtec/WBtecultratrans.html?q=Wire%20Bonding%20Ultrasonic%20Transducer
If you can not open the link above, search in the help manual for the: Mechanical Technology Showcase: Example Problems Chapter 39: Wire Bonding Ultrasonic Transducer
There is a public version of help now:
https://www.ansys.com/en-gb/blog/get-ansys-help-you-need-when-you-need-it
 public version of the Ansys Help site
All the best
Erik
