Ansys Free Student Software
DMP and SMP
    • cplasf1998
      The computer configuration is 2 CPUs, 96 cores.ANSYS use DMP mode to solve the finish, the result merge takes a long time, if force close and open again is not right.SMP mode can solve, but the solution speed is very slow. SMP mode can be solved, but the solution speed is very slow. The same number of cores in the case of DMP speed is 4 times the speed of SMP.
    • Gary_S
      DMP calculation is generally faster for the numerical calculations and is the default recommendation.
      A drawback to DMP can be the amount of time it takes to merge result files. This result file
      merge time is often small compated to calculation time of large modes that may take hours or days to solve.
      This is why it is important to have fast disk systems, usually SSDs or HPC file systems.
      There are two really good sections in the Ansys Help that I consider prerequisite reading when you get some time:
         Mechanical APDL > Performance Guide   Performance Guide (ansys.com)
         and
         Mechanical APDL  > Parallel Processing Guide.  Parallel Processing Guide (ansys.com)
