Ansys Learning Forum Forums Installation and Licensing Ansys Products How to get the rotations of each node in a plate modeled through solid elements? Reply To: How to get the rotations of each node in a plate modeled through solid elements?
Mehdi Baghaee
/BATCH
/input,menust,tmp,''
WPSTYLE,,,,,,,,0
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
/GO
/PREP7
ET,1,SOLID185
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,1e9
MPDATA,PRXY,1,,.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,6700
BLOCK,0,10,0,10,0,1,
FLST,5,8,4,ORDE,2
FITEM,5,1
FITEM,5,-8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
MSHAPE,0,3D
MSHKEY,1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
*dim,impulse,table,3
*SET,impulse(1,1),1,0       ,  0              ! VALUES OF EXCITATION
*SET,impulse(1,0),0,22*timestup,  1 ! CORRESPONDING VALUES OF TIME
F, 177, FZ, %impulse%
WPSTYLE,,,,,,,,0
FLST,2,44,1,ORDE,12
FITEM,2,1
FITEM,2,-11
FITEM,2,122
FITEM,2,143
FITEM,2,153
FITEM,2,-161
FITEM,2,243
FITEM,2,-244
FITEM,2,267
FITEM,2,-268
FITEM,2,287
FITEM,2,-304
/GO
D,P51X,ALL, , , , , , , , , ,
ANTYPE,4
TRNOPT,FULL
LUMPM,0
FINISH
/SOL
NSUBST,1000,0.01,0.001
OUTRES,ERASE
OUTRES,ALL,ALL
TIME,1
SOLVE
/post1
set,last,last
*dim,node11,array,2,3,1
node11(1,1)=nx(11)
node11(2,1)=nx(11)+ux(11)
node11(1,2)=ny(11)
node11(2,2)=ny(11)+uy(11)
node11(1,3)=nz(11)
node11(2,3)=nz(11)+uz(11)
*vfun,local11,local,node11(1,1),12
faced error!
