Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Memory Management Alert for Implicit Analysis in LS-DYNA After Version R10 › Reply To: Memory Management Alert for Implicit Analysis in LS-DYNA After Version R10
November 11, 2024 at 5:23 pm
Please set the memory using the suggested values in the alert. For example, if the mes0000 file shows below alert, try "memory=200m memory2=200m" in the ls-dyna command (for MPP solvers) or just "memory=200m" (for SMP solvers). Â
A sample SMP command is: /path/ls-dyna i= input.k memory=200m
== IMPLICIT USAGE ALERT ==
== Memory Management for Implicit has changed ==
== after R10. Please use: ==
== memory= 122M memory2= 122M ==
"Â
