Ansys Learning Forum Forums Discuss Simulation General Mechanical Challenges with Importing Complex Geometries into ANSYS APDL Reply To: Challenges with Importing Complex Geometries into ANSYS APDL
me262
Thank you for the quick response.
Currently, I'm working with Parasolid and ANF files and using vscale. I’ve noticed that vscale might be contributing to some issues. To investigate, I created two simplified test blocks. When I apply vscale to the geometries before using vglue, errors occur. However, if I reverse the order and apply vglue first, everything works smoothly.
I’ll conduct further tests on my current geometry to confirm if this approach resolves the issue—if I can find the time. If more questions arise, I hope I can continue to receive support here, if possible.
