Ansys Learning Forum Forums Discuss Simulation Electronics Question about corner cuts for a circular polarization of Patch antenna Reply To: Question about corner cuts for a circular polarization of Patch antenna
Kihyun Kong
Hi, Kristiyan
The GPS Patch antenna from the Antenna Toolkit in HFSS is a good reference.
The models created with the toolkit are treated as variables, so you can see how to cut corners.
