The solver failed with a non-zero exit code of : 2
    • vsmlingam
      Update failed for the Solution component in Fluid Flow (CFX).  The solver failed with a non-zero exit code of : 2Update failed for the Solution component in Fluid Flow (CFX).  The solver failed with a non-zero exit code of : 2
      Hi friends - I am working in the analysis of hydrodynamic analysis of dolphin - In this trail simulation - I set a boundary condition of dolphin swim in a Pool - I set all surrounding as free wall - open is at 1 atm relative pressure - Also i assign a local co-ordinate system fo Dolphin - There is no error in Ansys cfx - but i got an error at solving a file - the error i got is
      "Update failed for the Solution component in Fluid Flow (CFX).  The solver failed with a non-zero exit code of : 2"
      Kindly help me to resolve the issuse
    • vsmlingam
      https://youtu.be/C47PYE45o_s
      ANSYS CFX - Hydrodynamic simulation Error - "The solver failed with a non-zero exit code of : 2"
      I attach a video file by the above link - regards "The solver failed with a non - zero exit code of : 2
      This is my first case - the Robotic dolphin swim inside a water tank - based on that i assign a boundary condition - there is no error in CFX - Pre setup - but while comes to solver I got a "Non-Zero Exit code of 2"
      Kindly give me your valuable suggestion for resolve this issuse
    • vsmlingam
      https://youtu.be/svbREzzNGVg
      I attach a video file by the above link - regards "The solver failed with a non - zero exit code of 2
      This is my first case - the Robotic dolphin swim in a sea against waves - based on that I assign a boundary condition - there is no error in CFX - Pre setup - but while comes to solver I got a "Non-Zero Exit code of 2"
      Kindly give me your valuable suggestion for resolve this issue
    • vsmlingam
      I also attach my Dolphin IGES file with the below link - Kindly help me for the above problems
      https://drive.google.com/open?id=1wspkbJvTANhI6B8ENczsIQtiHPTJBldw
    • DrAmine
      What about the out file of CFX? Any hints there?
    • vsmlingam
      Dear sir,
      Sorry for my mistake, Due to more memory Ansys file i can't upload it - But i considered two case
      1. dolphin as a solid domain & inside a Swing tank fluid domain with a moving velocity about local co-ordinate Coord 1 -
      2. Dolphin as a solid domain inside a sea - fluid domain with a moving velocity about local coordinate 1
      In both cases - No error is shown in CFX Pre - Boundry set up - but when I click start run - it shows
    • vsmlingam
      Here I attach my second case cfx file, sir : https://drive.google.com/open?id=1MRTXa9JMohLcFjryjStFXodhTZWnPKfq
    • DrAmine
      Just tell us what you have in the outfile as additional message. Ansys staff do not look into any attachments
    • DrAmine
      Try to move the dolphin instead of the fluid domain
Viewing 8 reply threads
  • The topic ‘The solver failed with a non-zero exit code of : 2’ is closed to new replies.
