Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ansys aqwa error › Reply To: ansys aqwa error
November 6, 2024 at 12:41 pm
Mike Pettit
It looks like you are using Nonlinear Catenary Cables to model your tension legs, but this cable type is not really designed for that purpose (the Aqwa solver expects a catenary shape). You could either simplify the problem by using any other (linear or nonlinear) cable type; or you could replace the cables with Tether/Riser connections, which use a finite element method to estimate the tether loads and dynamic behaviour.
I hope this helps!
Mike
