Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Vibroacoustic › Reply To: Vibroacoustic
November 5, 2024 at 4:15 pm
tabajabassel12
Thank you again for sharing these resources!
I’ve gone through the setup as recommended, including configuring two physics regions (water for acoustic and EPDM for structural) and applying the necessary boundary conditions. However, I’ve run into a bit of an obstacle with the material data in the Engineering Data library—I couldn’t find the required properties for EPDM and borosilicate glass (isotropic Elasticity, density,speed of sound, viscosity ... )
Thanks once more for your help and guidance!
Best regards,
Bassel
