Ansys Learning Forum Forums Discuss Simulation Fluids Correct CFX Pre Setup to avoid isolated fluid regions Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
Mark O
PS. Another option is to not mesh the outside and just mesh the mussel with its inlets an outlets. Ultimately you have to decide what it is about the flow solution that you want to solve for and what it is that you know in advance about where and how much is coming in or going out and that will decide where to place the boundaries.
